2004 Mercedes Benz CLK320 car turned off
TONE215
Engine Mechanical problem
2004 Mercedes Benz CLK320 6 cyl Wheel Drive Type unknown Automatic 58000 miles
my car turned off while driving and now wont start back up. it cranks up but wont start. wat could it be thank u.
Mar 18, 2008 at 3:30 PM
WESTCOAST619
  • 16 POSTS
Most likely the fuel pump of crank sensor. If it stars when the car is cold, then I would go with the crank sensor. You could also look under the hood and check if you have any fuel at the test port on the fuel rail. Push the valve in an let it drain the fuel. Then crank the engine, fuel will squirt out so be carefull. If no fuel come out, most likely a fuel pump. Ive seen more crank sensor fail than fuel pumps. Hope this helps
May 6, 2008 at 2:22 PM
