Fuel Pump
2002 MERCEDES BENZ CLK320
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOBYDAVIS8520
Where is the fuel pump and filter located on this car and how do you access them?
Sep 8, 2008 at 8:47 AM
GFIMOTORCARS
  • 673 POSTS
The fuel pump is located in the fuel tank, but you can access it from the trunk of this vehicle. Pull out your trunk floor and you will see a black plastic cover at the back (closest to the front of the car) of the trunk. Remove this panel. Under the panel you will see a cover with three bolts. This is covering the fuel pump. Remove the cover and you can access the pump assembly. As for the filter, it is located in the right rear of the vehicles undercarriage. It is forward of the axle behind a black cover held on with 10mm plastic nuts. Remove the cover and you will have access to the filter.
Jan 13, 2009 at 4:35 PM
