2000 Mercedes Benz CLK320 AC blowing hot air
2000 MERCEDES BENZ CLK320
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRYSTALP08
I just replaced a new air compressor and added freon but it is still blowing hot air. I am waiting on the drier filter but don't know if that is the cause of the problem. What is a common problem and how can I repair it?
Aug 27, 2010 at 10:59 PM
Did you put the correct amount of freon if so-when you turn AC On do you hear the magnetic clutch engage the compressor-if not could be the clutch, low pressure switch and AC clutch relay-
Aug 27, 2010 at 11:02 PM
