1999 Mercedes Benz CLK320 convertible top doesn't work
100,000 MILES • 6 CYL • FWD • AUTOMATIC
MROBEY8
My 99 clk convertible top quit working. Mercedes wanted roughly $4000 to start trying different parts such as pump motor. Pump Motor tested fine when I had it tested, control module replaced and still didn;t fix problem. Both limit Switches in trunk are working.
Wndows go down when top is unlatched in front. No lighted indicators signaling for problems regarding misposition of components. Fuses are not burned out. WIll reward solution
Apr 5, 2010 at 11:46 AM
BIRDDOG100
I had a similar problem and it was a broken cable on the passenger side of the convertible top.
When the top is unlatched it would not stay in the up position and now that it's fixed it stayes up fine and wokks like it's supposed to.
Oct 15, 2010 at 5:51 AM
