2000 Mercedes Benz CLK230
SIMMI
Drive Train Axles Bearings problem
2000 Mercedes Benz CLK230 4 cyl Two Wheel Drive Automatic
it drives slow and does not pick up speed. it stops frequently on the road
Feb 10, 2009 at 9:40 AM
GFIMOTORCARS
  • 673 POSTS
This could be a fuel delivery issue or a sensor failure issue. You may have either a plugged fuel filter or failing fuel pump which will cause poor performance and stalls. With that said, failure of key sensors like the MAP or Crankshaft Position sensor can cause intermittent stalls as you have described. I wonder, do you have any warning lights on in the dash,
Feb 10, 2009 at 4:27 PM
