When driving at highway speeds, rear end sways. the swaying is greater when taking a gradual, highway speed, turn to the right.
Jan 15, 2010 at 8:49 AM
LOU P
✓Experienced Mechanic
Most often times when the vehicle does not feel stable it is due to a alignment issue or loose suspension component , also in rare cases a bent wheel or bad tire can cause the same when more load is applied to the affected tire.
