2003 Mercedes Benz C280 AIR BAG /OILCHANGE RESET CONNECTOR
69,576 MILES • 6 CYL • 2WD • AUTOMATIC
CARLOS MARTINEZ
PLEASE DESCRIBE FOR ME THE LOCATION OF THE
CONNECTOR TO RESET THE SRS AND THE OIL CHANGE. MY CAR IS A C 240.
2 WEEKS AGO A DIME FELL INTO THE CIGARETTE
LITTER TERMINAL AND BLOW THE FUSE, WHEN I TRY TO CHANGE THE FUSE I PULL THE SRS FUSE AND DISACTIVED THE SYSTEM
I KNOW THERE IS A RESET TOOL THAT I LL BE ABLE
TO GET AFTERMARKET BUT,NEED TO FIND THE SIZE
OF DE CONNECTOR.
I DO MOST OF THE MAINTENANCE OF MY VEHICLES AND I HAVE A GOOD MECHANICAL KNOWLODGE.
SOME INFO ABOUT THE RESET TOOL WILL BE A GOOD HELP AS WELL.
THANKS FOR YOUR HELP ON THIS MATTER
Oct 31, 2008 at 4:27 PM
GFIMOTORCARS
  • 673 POSTS
To reset the SRS light you will need a diagnostic scanner for an OBD II vehicle. These can be found at Autozone and will read and erase your stored codes. As for the oil reset light. Turn your vehicle on to key position 2 (position just before ignition). Scroll to your service reminder. Now press and hold the reset button on the left of your insturment cluster until the reminder resets (5-10secs).
Jan 6, 2009 at 2:13 PM
