1997 Mercedes Benz C280
185,000 MILES • 6 CYL • FWD • AUTOMATIC
LORIWEST
REPLACED THE INTAKE CAM DUE TO BEING BROKEN- THE CAM WE REPLACED IT WITH HAS TWO TRIGGERS ON THE SPRCKET FOR THE CAM SENSOR. THE ORIGINAL ONE ONLY HAD ONE- IS THAT WHY WE ARE COMING UP WITH A CODE OF PO341 CAM SENSOR HALL EFFECT CODE. IS HAVING TWO TRIGGERS CONFUSING THE ECM????
Sep 18, 2008 at 7:24 AM
2CARPRO JACK
  • 11,533 POSTS
Most likely. You should have used the same gear as the old cam
Sep 18, 2008 at 7:44 AM
