1996 Mercedes Benz C280 Oil in water / Oil leak on manifold
1996 MERCEDES BENZ C280
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEITH2008
I just replaced valve cover gasket, oil is still leaking on manifold. Smokes while running from under hood. Also found small traces of oil in radiator water.
Jul 10, 2008 at 8:21 AM
GFIMOTORCARS
  • 673 POSTS
Oil in the coolant is a clear indication of a blown head gasket. As for the valve cover, make sure your sealing surface is clean before you install any gaskets. Your smoke is more than likely being caused by oil leaking onto the exhaust manifold.
Jan 6, 2009 at 2:16 PM
