2005 Mercedes Benz C240 Front Crank Shaft Damper Pulley
2005 MERCEDES BENZ C240
16,800 MILES • 6 CYL • 2WD • AUTOMATIC
SLIMM
Should dealer replace under warrantee crank shaft damper pulley protruding out ~1-2mm between pulleys? (gasket that sits between the two circular pulley wheels, can easily be seen by opening the hood and looking behind the radiator towards the engine face). My local repair shop says yes, but the dealer said it's still within limits, and my warrentee expires 27 Jan 09!
Jan 16, 2009 at 10:01 AM
IMPALASS
  • 3,112 POSTS
Hello - I think this is what you need. To me, if I am reading this right it is out of limits. This says .4 to .5 depending on the engine, again, if I am reading it correctly. Now I may be wrong ..so.........I would ask them to show you in the book and give you a printed copy. I hope this helps Testing and Inspection Notes Inspecting belt pulley / vibration damper for axial and radial runout
https://images.2carpros.com/forum/automotive_pictures/248015_Picture1_46.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture2_37.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_Picture3_25.jpg
Jan 16, 2009 at 10:24 AM
IMPALASS
  • 3,112 POSTS
Hello –
Hey also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you. I would check these out also……
2008010001A
02/20/2008
Campaign - Catalytic Converter Inpection/Replacement
2006020008D
01/19/2007
Campaign - A/T Pilot Bushing Inspection
2006080003
08/01/2006
Campaign - COMAND(R)/Navigation Software Update
2005030003
05/01/2005
Campaign - Lower Door Seal Modification
2005030005
05/01/2005
Campaign - Door Frame Corrosion
2006020005
03/01/2006
Recall - Driver Air Bag Replacement
NHTSA05V560000
12/15/2005
Recall 05V560000: Air Bag Defect/Replacement
Jan 16, 2009 at 10:46 AM
