How do I set or losen the belt tension so that I can replace the alternator...
Feb 9, 2009 at 9:41 PM
GFIMOTORCARS
✓ASE Certified Mechanic
The belt tensioner is an automatic tensioner. The tension can be remove by using a wrench on the nut of the tensioner pulley. USe a longer wrench as it will give you better leverage. Let me know if you need any further details.
Feb 11, 2009 at 12:46 AM
