2002 Mercedes Benz C240 battery
2002 MERCEDES BENZ C240
40,521 MILES • 6 CYL • 2WD • AUTOMATIC
KRAMMAUI
I just put in a new battery, cleaned off the terminals, and a week later it will not start. The in dash computer does not show any charging problems.
Sep 13, 2009 at 2:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is engine cranking over or do you just get clicking when turning key?
if clicking, need to have your starter tested. if crank but no start, check spark at the plugs and ensure fuel pressure is correct.
Sep 13, 2009 at 2:21 PM
KRAMMAUI
It will start if I jump it. So I do not think it is the starter
Sep 13, 2009 at 2:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, since it drove for a week on the new battery, it seems as if the alternator is actually at fault. If the alternator is weak it will not charge the battery properly, meaning that the vehicle will use the battery to run on. The battery will then drain dead within a few days. I suggest having the alternator tested to ensure it is charging properly.
Sep 13, 2009 at 2:54 PM
KRAMMAUI
Thank you. Would the in dash computer show a charging problem is it was not charging?
Sep 13, 2009 at 3:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Most likely not until the battery is almost drained.
Sep 13, 2009 at 3:01 PM
KRAMMAUI
It clicks, but If I jump it starts rightup. It does not say Undervoltage or any charging/battery problem on the dash computer
Sep 13, 2009 at 3:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
most part stores will test your charging system for free. let me know how the test results read out.
Sep 13, 2009 at 3:21 PM
SANJAY DEVANI
I believe I may have a similar problem. See my question under subject "Mercedes Benz C240 Battery or Alternator". Was it the Alternator in your case? If not, what was the root cause?
Dec 22, 2009 at 4:14 AM
