2007 Mercedes Benz C230 altenator
2007MBZ
Noises problem
2007 Mercedes Benz C230 6 cyl Automatic 41,200 miles
When starting the engine it is making a strange sound. I asked a mechanic and he said the altenator is about to go in a few weeks. I'm still under the MBZ warranty, so shouldn't it be covered? Also, how much should new front brakes cost?
Thanks!
Nov 7, 2010 at 8:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
For original warranties, it depends on the level of warranty. Usually for the first year or two on a new car it would be covered, but after that, only if you have the premium extended warranties.
For aftermarket and used vehicle warranties, most basic ones won't cover electrical components like the alternator. The upgraded ones usually will though. Best to ask the warranter or read your warranty details.
Labor for replacing both front brake pads should be about 1 hour which is equal to about $80 - 100 depending on the shop. You can price the parts yourself depending on which brand and store you choose will make a big swing in pricing.
Nov 7, 2010 at 3:57 PM
2007MBZ
OK! Well, it's the front brake rotors on this Mercedes, so I'm sure it will be more than 80 dollars-----more like 800. I wish anything on a MBZ could be fixed for 80.00!:-) But thanks for your good dream reply.
Nov 8, 2010 at 12:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if you let a shop charge you 800 bucks to replace front rotors on your car thats your own fault, there is nothing special about replacing rotors on this merc than any other vehicle and it only takes about 1 1/2 labor hours to do so..unless they are charging you over $400 an hour than there is no way it will cost that much. I even found new rotors at $100 each, so even including 2 new front rotors and labor shouldnt be more than $400...
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2900.jpg
Nov 8, 2010 at 8:42 AM
2007MBZ
I'll definitely keep these figures in my mind. Thanks!
Nov 8, 2010 at 10:09 AM
