2005 Mercedes Benz C230 high speed vibration when turning
50,952 MILES • 4 CYL • 2WD • AUTOMATIC
ALISTAIR_L
Hello I have a 2005 C230 Kompressor. The car just had its right upper and lower control arms replaced. I am getting a vibration when i take left hand turns on the freeway at high speeds 70-80mph. It only happens on left hand turns.
Feb 7, 2010 at 2:49 AM
LEGITIMATE007
  • 5,121 POSTS
ok , it could be several things, it will need a safety inspection in order to determine, what exactly is causing this, tie rod ends, inner tie rods, ball joints(mostlikely), and swaybar/sway bar bushings and links, but you wont know until inspected, and there is no need to bring it to a mercedes dealer or any dealer for that matter, prices are just too high, a regular shop will suffice
Feb 7, 2010 at 2:52 AM
ALISTAIR_L
It just passed a safety last Friday. The car had upper and lowers changed two weeks ago. On the 2005 C230 sedan the control arms and the ball joints are one unit. so all of them have been replaced on the the one side.
Feb 7, 2010 at 3:56 AM
LEGITIMATE007
  • 5,121 POSTS
excellent, they may have overlooked something, I would still check tierods, inner and outer, and dont forget about the alighnment, some people like to take shortcuts and say they did the job , dont fall for it, the car isnt vibrating for no reason!! take a look at the tires for good measure, you never know, the tiniest of things can be causing this
Feb 7, 2010 at 10:39 PM
ALISTAIR_L
They did fix the two lowers but didnt do it properly so they offered to fix it for free but I turned them down since they didnt do it right the first time and I just took it to Mercedes and spit the tab with them 4 new tires and two lower tie rods and the grand total was 1700 bucks
May 3, 2010 at 1:39 PM
LEGITIMATE007
  • 5,121 POSTS
wow, what an ordeal, and what a price, I'm atleast glad you have your vehicle back to normal. keep and touch
May 4, 2010 at 1:10 AM
