2005 Mercedes Benz C230 Alarm Key Not Working
2005 MERCEDES BENZ C230
50,000 MILES • 4 CYL • FWD • AUTOMATIC
PLUMMIE
I Changed Battery On My Car Key For Alarm Now Alarm Not Working
Feb 28, 2009 at 10:50 AM
GFIMOTORCARS
  • 673 POSTS
First make sure the battery is properly seated. Next make sure that the contacts on the key are free of corrosion. If the contacts on the key look worn use a small piece of very fine grit sand paper to scuff the contacts on the key. Also if you have a second key test the other key on the alarm. If the alarm works with this key you know your problem is something with the key and not the car. There is no renormalizing process for just changing the battery on the key so there must be something simple that has caused this to happen.
Feb 28, 2009 at 2:27 PM
ECOCONUT
Hmmmmm! Make sure the new batteries that u just put in the key is install correctly. If that's ok. If the Car battery is weak the remote/alarm/security will not work.
Jan 4, 2010 at 10:33 PM
