2004 Mercedes Benz C230 code P0715
56,384 MILES • 4 CYL • 2WD • AUTOMATIC
CML5456
  • 8 POSTS
MBZ C230, this car has shown total of 4 codes, (P0172, too rich bank 1), (P0128, coolant temp below thermostat), (P0170, fuel trim malfunction bank 1), (P0715, imput/turbine speed sensor A). car drive like it was out of gas, no power, but it drive in slow speed. i believe the first 3 codes was caused by code P0715, but i am not too sure and not know which sensor causes this. any hitech people had experience fixing this problem? Oh, this car has turbo, it is a kompressor. thank you!!
Dec 11, 2009 at 2:54 AM
MMPRINCE4000
  • 8,548 POSTS
The turbo has a problem (bearing, seal) or the sensor is bad.
Remove intake to compressor side of turbo, grasp the compressor wheel, if it has ANY vertical or lateral movement, then you will most likely have to replace turbo cartridge. Also inspect compressor wheel for "knicks" on blades and any deformed blades. Proper lubrication to turbo is CRITICAL.
How much boost are you getting? (psi,kpa). Is there any blue smoke out exhaust.
Do you use a full synthetic oil?
The rich and fuel trim problems are turbo related. The coolant code may be unrelated.
Dec 13, 2009 at 12:30 AM
