2003 Mercedes Benz C230 put thermostat on a 2003 c230
MR503_NC
Engine Cooling problem
2003 Mercedes Benz C230 4 cyl Two Wheel Drive Automatic
how do you put on a thermostat on 2003 c230 and where it is on the motor can you help me on this
Jan 28, 2010 at 1:11 PM
BLUELIGHTNIN6
  • 16,542 POSTS
unclip cover on front side of engine (if apllicable)
remove engine cover with integrated air filter
detach coolant hose
remove poly-V belt from guide pulley
unscrew bolts and remove coolant thermostat housing with coolant thermostat
installation is reverse order then inspect cooling system for leaks.
Jan 28, 2010 at 1:43 PM
