2003 Mercedes Benz C230 auto drivers seat
2003 MERCEDES BENZ C230
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
JDHARTZ
automatic seat ondriver's side will not move passenger's seat still works also stearing wheel will not adjust. It also is automatic.
May 28, 2008 at 2:37 PM
DISCOSTU24000
  • 37 POSTS
You'll need a digital multimeter.DONT use a test light or an analog meter, you'll damage the seat control module. If you don't know how to do basic electrical tests then I wouldn't recommend that you try to diagnose this yourself. There are two motors, one that controls seat height and another that moves the seat closer or further from the steering wheel. Since the seat doesnt move in any direction it's probably not a motor problem. Check the fuse first, if it's good, then disconnect the relay and test it. if both check out good, then check to see if your're getting voltage from the module. Last thing to check would be the switch for coninuity.
Jun 5, 2008 at 8:57 AM
DISCOSTU24000
  • 37 POSTS
oh, i forgot about the steering wheel. From what I can see their wiring and controls are not related so it's most likely two seperate problems.
Jun 5, 2008 at 9:00 AM
B3NKO
Hey, this may be off topic, but I was hoping you could help me locate a driver seat for a 2000 C230. I am considering purchasing this nice example in town that's going for a great price, but the driver's seat is missing and would obviously need to be replaced. I'm not even sure how much they go for if they are in fact available. Any help would be greatly appreciated. Thanks.
Sep 29, 2008 at 2:31 PM
