2002 Mercedes Benz C230 transmission fluid
2002 MERCEDES BENZ C230
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEVITYAMI
How do i get the dip stick out to put transmission fluid in it.
Mar 14, 2009 at 3:39 PM
GFIMOTORCARS
  • 673 POSTS
There is a small wither black or red tab that sits on top of the trans filler tube. This is a lock. You will break the tab off by twisting it back and then use a small screw driver to push the remaining portion of the lock through. You will be able to purchase a new lock from a Benz dealer or local repair shop for a couple bucks.
Mar 16, 2009 at 4:48 AM
