2002 Mercedes Benz C230 front two blinkers
2002 MERCEDES BENZ C230
SELMAC
Electrical problem
2002 Mercedes Benz C230 4 cyl Manual
I have three blinkers on each side of my car. Two in the back, two on the side mirrors, and two up front. The two front ones do not work. Does anyone know what the problem could be?
Thanks.
Mar 19, 2009 at 11:58 AM
GFIMOTORCARS
  • 673 POSTS
If the bulbs are good check the internal contacts of the bulb connector. If you see any evidence of corrosion or electrical arching you will need to replace the bulb connector assembly.
Mar 22, 2009 at 5:54 AM
