2000 Mercedes Benz C230 ESP/Bal light
ALLI&MARGIA
My ESP/BAL light will not turn off. I checked the fuse and it is good. Any ideas what's wrong with it?
Jul 6, 2008 at 11:31 PM
GFIMOTORCARS
  • 673 POSTS
If you have recently disconnected the battery you more than likely just need to reinitialize your steering angle sensor. This can be don e by turning on the vehicle and rotating the steering wheel from far left to right (until the steering wheel stops) 4 times. If this is not the case, then you more than likely have a failed steering angle sensor.
Jan 10, 2009 at 5:31 AM
