1999 Mercedes Benz C230 Coolant indicator light/coolant sen
1999 MERCEDES BENZ C230
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
REXLAWS
Coolant light on and off sporadically. NOT overheating. NOT losing coolant. Temp. gauge on dash is reading 80 degrees C, normal. How do I replace the coolant sensor inside the coolant bottle a k a reservoir?
Jan 15, 2010 at 9:13 AM
2CARPRO JACK
  • 11,533 POSTS
First you may want to call M/B and see if it is serviceable seperatly.Some are made into the resevoir and arent replaceable but as an entire piece.If replaceable, there will be a sliding retainer clip that holds the sensor in the resevoir, the new sensor should come with a new o'ring, if not be sure to get one while at M/B. simply plug new sensor in the resevoir, slide retainer in and reconnect electrical
Jan 19, 2010 at 11:44 PM
