1998 Mercedes Benz C230 replacing crankshaft position senso
HUGO
Engine Mechanical problem
1998 Mercedes Benz C230 4 cyl Two Wheel Drive Automatic
Where is the crankshaft position sensor loacted. I baught a replacement.
Oct 1, 2008 at 6:16 AM
GFIMOTORCARS
  • 673 POSTS
Your crankshaft position sensor is located on the drivers side bell housing. You can locate it by opening the hood and standing on at the drivers side fender. With a flashlight look behind the motor to the bell housing. On the drivers side of the bell housing you will see a sensor mounted into the housing. This is your cracnkshaft position sensor.
Jan 10, 2009 at 4:41 AM
