check engine light reset?
97,500 MILES • 4 CYL • 2WD • AUTOMATIC
FRANKBRITTO
how do i reset check engine light ?
Nov 18, 2008 at 2:18 AM
DISCOSTU24000
  • 37 POSTS
you need a scan tool to reset the check engine light. you can buy a cheap one at an auto parts store for about $30 or you can take it to a shop and they'll probably reset it for pretty cheap. if you havent corrected the problem thats causing the light to come on then it will probably come back after the reset.
This video will show you how
https://youtu.be/ahK_eucFi-k
Nov 20, 2008 at 5:51 AM
RAYMOND ALEX
I am in the service I have been away for 9 months I replaced my battery and now my computer needs to be reset I need your help
Aug 3, 2020 at 8:25 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
Your battery needs to be registered with the computer and that can only be done with a professional scan tool so you will likely have to visit a well equipped shop to do that.
2CP-ARCHIVES
  • 4,540 POSTS
How do you reset check engine light?
KHLOW2008
  • 41,812 POSTS
An error has been detected by the engine management system and you need to rectify the fault before it can be reset. Retrieve the trouble codes and let us know what it is and we can advise on how to rectify the problem.
