1997 Mercedes Benz C230 Will not pass state inspection
107,453 MILES • 4 CYL • 2WD • AUTOMATIC
RALPH GERARD
  • 7 POSTS
I have just purchased this vehicle for my daughter, the engine had been only running on two cylinders so I changed the coil packs, plugs, air filter, fuel filter, P.C.V. valve, also had to change battery, upon completion vehicle runs fine, when I took it in for state inspection it failed for trouble code P1070, can anyone please help me with this problem.
Jul 17, 2008 at 9:41 PM
  • 75,988 POSTS
You sure its P1070 or P0170 which one?
Jul 17, 2008 at 11:07 PM
RALPH GERARD
  • 7 POSTS
[quote:df1b5555e5="rasmataz"]You sure its P1070 or P0170 which one?[/quote:df1b5555e5] sorry it is P0170
Jul 18, 2008 at 5:50 AM
  • 75,988 POSTS
P0170 its a fuel trimming problem -verify the oxygen sensor/s switching activity
Jul 18, 2008 at 10:17 AM
RALPH GERARD
  • 7 POSTS
[quote:fe4970ecd5="rasmataz"]P0170 its a fuel trimming problem -verify the oxygen sensor/s switching activity[/quote:fe4970ecd5]Both oxygen sensor's have been changed
Jul 22, 2008 at 9:20 PM
RALPH GERARD
  • 7 POSTS
[quote:731eada61f="rasmataz"]P0170 its a fuel trimming problem -verify the oxygen sensor/s switching activity[/quote:731eada61f]Both oxygen sensor's have been changed
Jul 22, 2008 at 9:21 PM
  • 75,988 POSTS
Try checking for vacuum leak and also injector's could be leaking and the fuel pressure regulator lfor eakage-
Jul 23, 2008 at 5:53 AM
RALPH GERARD
  • 7 POSTS
The problem turned out to be the mass air flow sensor, thank's for the help, Ralph Gerard
Aug 3, 2008 at 9:32 PM
