There is hot air coming continuously into the passenger compartment regardless of the temperature setting. Seems like some sort of regulating valve is stuck in the open position and is not responding to the temperature knob.The air conditioning gas has been refilled but this makes no difference i.e. the heat just stays on.
Is there a simple method by which I could remove a fuse or disconnect a switch to eliminate this problem. I want to avoid expensive diagnostic investigations as long as I am able to prevent the hot water circulating in the heater element.
Thank you
Thank you
Nov 11, 2008 at 2:47 PM
