2002 Mercedes Benz C220
GFABZZZ
Transmission problem
2002 Mercedes Benz C220 6 cyl Two Wheel Drive
the tiptronic has will not engage and when in normal drive it will not get passed 1st, but all others are fine... park, reverse are fine, manually it wont go past 1st, so basically stuck in first gear on both transmissions. HELP! please
May 22, 2010 at 1:58 AM
  • 31,937 POSTS
HI there,
This is a rather complex system, i would advise that it is checked by a Benz tech only, if you can get a diagnostic scan done and report any set fault codes i may be able to give you some more details on this problem,
mark (mhpautos)
May 22, 2010 at 3:14 AM
