Could anybody help in explaining how to remove the wing mirror outer casing to enable the replacement of the indicator unit
Mar 9, 2009 at 2:43 AM
GFIMOTORCARS
✓Experienced Mechanic
Put the mirror in the down position. Look behind the mirror and you will see a thin metal wire holding the mirror on. Lift this wire with a small screwdriver. This will relaese the mrrior and will give you access to the set screws for the indicator.
