2004 Mercedes Benz C180 CAr Mirror
2004 MERCEDES BENZ C180
31,000 MILES • 4 CYL • 2WD • AUTOMATIC
LINGPARKJACK
Could anybody help in explaining how to remove the wing mirror outer casing to enable the replacement of the indicator unit
Mar 9, 2009 at 2:43 AM
GFIMOTORCARS
  • 673 POSTS
Put the mirror in the down position. Look behind the mirror and you will see a thin metal wire holding the mirror on. Lift this wire with a small screwdriver. This will relaese the mrrior and will give you access to the set screws for the indicator.
Mar 31, 2009 at 5:09 PM
