1995 Mercedes Benz C180 DOOR LOCK
101,000 MILES • 4 CYL • 2WD • AUTOMATIC
FRANK BULLOCK
DEAR SIRS, I NEED TO CHANGE LOCK ON DRIVERS DOOR, I CAN SEE THE NEW KEY PART HAS A SCREW HOLE AT THE BACK BUT WHEN I REMOVE THE INNER DOOR COVER THERE DOSE NOT SEEM TO BE ANY ACCESS TO GET TO THE SCREW
Jun 9, 2010 at 4:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for donating
when replacing the front door lock switch, you first remove the door panel. once it is removed you should find some door foil in the door lock area. remove that as well. once that is removed you should be able to see the door lock switch to disconnect it from the door lock. to do so you must press a catch lug outward with plastic wedge, lug is on the switch housing behind the electric lead.
Jun 25, 2010 at 7:50 AM
