1999 Mercedes Benz A140 Windows
60,000 MILES • 4 CYL • FWD • MANUAL
KENZWORLD
My electric windows no longer work. The problem was periodic and I was able to open the windows after turning off the engine. This trick no longer works. Could it be the fuses? I looked at the fuse chart and noted that there are two fuses dedicated to the windows. Should I change them both?
Thanks in advance for your help.
Oct 4, 2009 at 10:07 AM
JEEPFAN
  • 135 POSTS
f none of your windows work i would suggest getting a test light and seeing if the master switch is sending power to the motor on most cars if the master switch goes out(the drivers door switch) none of the others will work
Oct 4, 2009 at 10:27 AM
