1989 Mercedes Benz 560sel addding transmission fluid
1989 MERCEDES BENZ 560SEL
106,000 MILES • V8 • 2WD • AUTOMATIC
DIAZ77
How do I add transmission fluid? I cant even find the transmission dipstick under the hood. Please help.
Jul 31, 2010 at 11:33 AM
  • 31,937 POSTS
HI there,
The transmission dip stick should be on the L/H/S at the back of the engine, viewed from standing at the front of the car, run engine and have trans warm to hot, check level, if low add as required, select each gear for a few sec and place in PARK, re check, repeat until oil is at correct level.
mark (mhpautos)
NB, this is for R/H/Drive cars, it should be located the same in L/H/Drive versions.
Jul 31, 2010 at 12:42 PM
