1991 Mercedes Benz 500sl Removing the right rear rotor
85,000 MILES • V8 • 2WD • AUTOMATIC
CLACY13
I am looking for any special tricks or procedures for removing the lock nut the holds on the right rear rotor on my 500 SL.
Feb 15, 2009 at 10:01 AM
GFIMOTORCARS
  • 673 POSTS
If you are speaking of the Torx set screw that holds the rotor to the hub, often times this gets seized due to rust. A trick to get this out is with some rust penatrent. If it still is stuck you may need an impact driver and a hammer to get it out fully. Also if you don't have a Torx bit to fit the screw, these can be purchased at auto parts stores.
Feb 15, 2009 at 1:25 PM
