1993 Mercedes Benz 500sec blower
J.BRENNANJR
Heater problem
1993 Mercedes Benz 500sec V8 Two Wheel Drive Automatic
blower just stopped working ? fuses ok heat still comes out when called for but with no blower assits controls seem to do there fuction AC i dont know if it still works
Jun 29, 2010 at 1:07 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
If fuses test good then check blower motor relay. If OK as well then the wiring at the blower motor should be tested. If power is getting to the motor but it is not coming on then motor needs replaced. If no power is getting to motor then it could be a faulty blower resistor or the control switches on dash.
Jun 30, 2010 at 2:15 AM
