1991 Mercedes Benz 500sec Rebuilt transmission 99,000 now 1
116,000 MILES • V8 • 2WD • AUTOMATIC
WMAYRES163
Starting out transmission some time slips on start up.
All other shifting functions seem okay.
Jun 10, 2010 at 2:10 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated
Transmission Slips When Starting Off In 1st
Band B-2 shift valve sticking. Band B-2 piston worn or damaged. Band B-2 adjusted incorrectly or worn or damaged. Adjust brake Band B-2 by installing a longer thrust pin (if necessary). If transmission operates properly with selector lever in "2", but not in "3" or "D" position, the one-way clutch may be slipping.
hope this helps
Jun 10, 2010 at 8:50 PM
