1991 Mercedes Benz 500sec Rebuilt transmission 99,000 now 1
WMAYRES163
  • 1991 MERCEDES BENZ 500SEC
  • V8
  • 116,000 MILES
Starting out transmission some time slips on start up.
All other shifting functions seem okay.
Thursday, June 10th, 2010 AT 9:10 PM
DAVE H
  • 13,384 POSTS
Hello. Thanks for the donation. Much appreciated
Transmission Slips When Starting Off In 1st
Band B-2 shift valve sticking. Band B-2 piston worn or damaged. Band B-2 adjusted incorrectly or worn or damaged. Adjust brake Band B-2 by installing a longer thrust pin (if necessary). If transmission operates properly with selector lever in "2", but not in "3" or "D" position, the one-way clutch may be slipping.
Hope this helps
Friday, June 11th, 2010 AT 3:50 AM
