1977 Mercedes Benz 450sl no fuel going to injectors
104,000 MILES • V8 • 2WD • AUTOMATIC
KEN1BEAM
i have fuel up to the fuel destributor but there is no fuel coming out to the injectors will run if i pour gas in it will run until the gas burns out what could be wrong
Jun 16, 2010 at 10:37 AM
DOCHAGERTY
  • 9,606 POSTS
If there is pressurized fuel to the distributor and none to the cylinders, the distributor is suspect. K-jet is pretty basic. Maybe a salvage yard for your distributor.
Jun 23, 2010 at 12:53 AM
SCOTTINSOCAL
  • 22 POSTS
As the message above points out, the fuel distributor is the likely culprit. These can be rebuilt - and they can be rebuilt as a DIY - but the job is not one I'd choose as an intro to mechanical work. Some of the components in there are very small and very delicate. Your best bet would be to buy a rebuilt.
Sep 24, 2010 at 10:28 AM
