1975 Mercedes Benz 450sl My car isn't pumping any gas
1975 MERCEDES BENZ 450SL
162,000 MILES • V8 • 2WD • AUTOMATIC
UAJONESY
Car Stats: 1. Recently installed a new coil, points & resistors. Also installed used fuel pump because a mechanic stated that my pump wasn't putting out enough pressure once the car was turned off.
Yesterday I tried to start my car and it wouldn't start.
The car seemed like it wasn't getting any gas.
This is what I did: 1. I unplugged the hoses it fuel delivery hose and placed the end in a bottle and cranked the engine, no gas came out of either hose.
Why isn't the fuel pump working, could it be the fuel pump relay?
Sep 25, 2009 at 8:50 AM
When you turn key to run -do hear the fuel pump come on? If not could be the fuel pump relay or fuel pump fuse. If it comes on no fuel pressure the pump is defective-
Sep 26, 2009 at 6:18 AM
