1991 Mercedes Benz 420sel WATER PUMP
1991 MERCEDES BENZ 420SEL
125,620 MILES • V8 • 2WD • AUTOMATIC
17855S
Is it nessary to remove the harmonic ballancer and distributor to replace the water pump, if so what size socket fits the bolt on the ballancer.
Jun 24, 2009 at 10:22 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated Hope this helps WATER PUMP Removal & Installation Disconnect necessary water hoses and components from water pump housing. Remove distributor and 8 water pump mounting bolts. Remove pump from vehicle. To install, reverse removal procedure. Let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_805.png
Jun 24, 2009 at 11:41 AM
