1982 Mercedes Benz 380sl Engine problem
LASZLO147
  • 1982 MERCEDES BENZ 380SL
Engine Mechanical problem
1982 Mercedes Benz 380sl V8 Two Wheel Drive Automatic? Miles
My crankcase has pressurized, I know it is pretty bad, however I would like to know if any one knows the probable cause(s).
Wednesday, November 4th, 2009 AT 12:32 AM
  • 31,937 POSTS
Hi there,
You may have a blocked PCV valve, but the excess pressure in the crankcase may be due to ring leakage, you will need to do a leak down test to see how bad things are.
Mark (mhpautos)
Wednesday, November 4th, 2009 AT 1:28 AM
