1994 Mercedes Benz 350sdl sluggish
287,000 MILES • 6 CYL • 2WD • AUTOMATIC
CRANEWMN
I have noticed the car is very sluggish going uphill or when I try to merge into fast traffic. Could it be the fuel filter? And are there 2 filters and where are they located?
Aug 15, 2010 at 7:35 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging,misfiring etc. could be caused by one of the following below:
Start here-inspect and test all the items below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Aug 15, 2010 at 2:31 PM
