1995 Mercedes Benz 320sl IGNITION COILS GETTING BURNT
40,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMWINDIA
I have an SL 320 and it is the second time that the ignition coil have been burn by its self. I have noticed that there was low voltage supply in 2 of them.
I have also checked the battery and the alternator, both seem to be ok.
what could be the problem?
Feb 14, 2010 at 5:59 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Check voltage on red/blue wires to each coil. Should be battery voltage. Also ohm check each coil across terminals, then from each terminal to ground.
Let me know
Thanks for donate
Feb 15, 2010 at 5:11 AM
