2001 Mercedes Benz 320e CODE MEANING
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCRENDIPITY
P0171 & P0174 BANK 1 & 2 RUNING LEAN WHAT DOES THIS MEAN AND WHAT REPAIRS ARE NEEDED.
Jul 27, 2009 at 8:47 AM
  • 75,988 POSTS
P0171/P0174 Lean condition
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires
Jul 27, 2009 at 2:13 PM
