2001 Mercedes Benz 320e check engine lights go on
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
When idling at red light, rpm's get so low the engine stalls so I have to put in neutral. Also the engine is running with temperature over 80 which is probably too high. What do you think problem are?
Aug 24, 2009 at 12:21 PM
  • 75,988 POSTS
2001 Mercedes Benz 320e check engine lights go on. You need to get the computer scanned for code/s to find out why the light came on. You have a problem within the engine management system. Autozone provides this service free. This is your starting point
Aug 24, 2009 at 12:34 PM
