2001 Mercedes Benz 320e
MARIANMAJ
Electrical problem
2001 Mercedes Benz 320e 6 cyl Two Wheel Drive Automatic
after a jump start my car windows go down but not up and radio says CODE and will not turn on sun roof opens will not close!!??
Mar 18, 2009 at 7:46 AM
GFIMOTORCARS
  • 673 POSTS
The windows an sunroof need to be renormalized. Roll the window up and hold the switch in the up position for each window for 10 sec. As for the sunroof with the sunroof closed hold the switch in the forward position. The code means you need to enter your radio code. This should be located on a business card size card in your owners manual. Enter the number on the card and hit the tuner knob. If you don't have it you may have to go to the dealer to have them source the code against the radio part #.
Mar 31, 2009 at 4:28 PM
