2000 Mercedes Benz 320e When I crank the engine the car won
DSAPENSION
Engine Mechanical problem
2000 Mercedes Benz 320e 6 cyl Four Wheel Drive 145690 miles
I tried startint the car, it owuld tturn over but the car won't start. After I got it started and i was driving it just shut off and won;'t start again.
Jun 28, 2009 at 5:30 PM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
If the check engine light is on, read the codes, the computer is trying to point you in the right direction.
Readers can be purchased by following the link in my signature file, this is a must do step for all computer controlled cars.
Jun 29, 2009 at 10:52 AM
