2000 Mercedes Benz 320e shifter
2000 MERCEDES BENZ E320
137,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOWRIDER
after the car is started, and with your foot on the break, the gear shift remains locked. Using the manual release the shifter can be put in drive and will move however will in shift automatically
Dec 10, 2008 at 4:49 AM
JAMES W.
  • 2,394 POSTS
There is an adjustable cable under the dash attached to the brake pedal. If this cable becomes slack from use it will not release the shifter. Cable adjustment is at the pedal. Hope this helps and thank you for the donation.
Dec 10, 2008 at 8:36 AM
