1999 Mercedes Benz 320e po300
AUTOKINGS2009
  • 9 POSTS
1999 Mercedes Benz 320e 6 cyl Automatic
Got po300 (random misfire). To keep a long story short I replaced the MAF but with no availe. Any suggestions?
Oct 23, 2010 at 10:18 AM
  • 75,988 POSTS
P0300 is normally caused by vacuum leaks and bad fuel-check EGR valve if it has one if its leaking
Oct 23, 2010 at 10:34 AM
AUTOKINGS2009
  • 9 POSTS
[quote:c7fd3e0807="rasmataz"]P0300 is normally caused by vacuum leaks and bad fuel-check EGR valve if it has one if its leaking[/quote:c7fd3e0807]
Tihs seems to be the most common suggestion. Thank you for the validation. I have used this site before and has been the most reliable. Thanks again
Oct 23, 2010 at 11:48 AM
