1999 Mercedes Benz 320e fuel filter
1999 MERCEDES BENZ E320
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
DKAVCAK
Where's the fuel filter located and is it difficult to change?
Mar 19, 2009 at 11:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Located under vehicle, passenger side, below seating area, front of fuel tank, mounted on frame in fuel line. Is a rather simple maintenance procedure. Just remember to relieve the fuel pressure before disconnecting line from filter. There will still be a little fuel that may squirt out of the fuel line when you first remove filter so be certain to wear proper protective gear.
Thanks for using 2CarPros.com!
Mar 20, 2009 at 3:09 AM
