1997 Mercedes Benz 320e vacuum leak
ARA245
Shakes or Wobbles problem
What's the easiest and best way to locate and repair a vacuum leak I know the general area where it is
Jun 27, 2009 at 1:47 AM
  • 31,937 POSTS
Hi there,
You can often use a length of hose and listen for a vacuum leak, or spray a small amount of starter fluid around and if you hit the leak the revs will jump up, as for the repair, this will depend on where it is, gasket leaks or vacuum hoses.
mark (mhpautos)
Jun 27, 2009 at 2:06 AM
